To display system status and technical information about the switch hardware components, use the show sys-info command. The command displays several pages of information, including general information about the system (such as location), chassis (type, serial number, and base MAC address), cpld, temperature, power supplies, fans, cards, system errors, port locks, topology status, and message control information.
You can identify a port-licensed switch with its part number. Use the command show sys-info to view the part number of the switch. For the list of part numbers of VSP 7200 Series switches with the option of port licensing, see Installing the Virtual Services Platform 7200 Series.
The syntax for this command is as follows:
show sys-info {card | cpld | fan | led | power | ssd | temperature | uboot | usb}
The following table defines parameters for the show sys-info command.
 Parameter  |
 Description  |
 card  |
 Specifies information about the device. Includes type, serial number, and assembly date. Note:
Not all hardware platforms support removable cards or modules. If a platform does not support removable cards or modules, the output provides information on the chassis as a whole. For more information, see the hardware documentation for your platform.  |
 cpld  |
 Specifies information about field programmable gate arrays (FPGA) and complex programmable logic devices (CPLD). Note:
This parameter is not supported on all hardware platforms.  |
 fan  |
 Specifies information about installed cooling ports.  |
 led  |
 Specifies LED information in detail.  |
 power  |
 Specifies information about installed power supplies.  |
                                                   ssd  |
                                                   Specifies information about installed modular Solid State Drives (SSD). Note:
 temperature  |
 Specifies temperature information.  |
 uboot  |
 Specifies uboot details.  |
                                                   usb  |
                                                   Specifies information about cached USB information.  |
The following examples show partial output from the show sys-info command for various switches. The output for this command will vary on switches because of hardware differences.
The following example shows partial output from the show sys-info command for a VSP 8284XSQ switch.
Switch:1>show sys-info
General Info :
        SysDescr     : VSP-8284XSQ (w.x.y.z)
        SysName      : Switch
        SysUpTime    : 0 day(s), 15:49:09
        SysContact   : http://www.extremenetworks.com/contact/
        SysLocation  : 9 Northeastern Blvd,Salem,NH. 03079
Chassis Info:
        Chassis            : 8284XSQ
        ModelName          : 8284XSQ
        BrandName          : Extreme Networks
        Serial#            : 14JP174C1013
        H/W Revision       : 1
        H/W Config         :
        Part Number        : EC8200A01-E6
        NumSlots           : 2
        NumPorts           : 85
        BaseMacAddr        : b0:ad:aa:43:48:00
        MacAddrCapacity    : 1024
        MgmtMacAddr        : b0:ad:aa:43:48:81
        System MTU         : 1950
Card Info :
        Slot#      CardType          Serial#            Part#             Oper     Admin  Power
        Status    Status  State
            1       8242XSQ     14JP174C1013     EC8200A01-E6               up        up     on
            2       8242XSQ     14JP174C1013     EC8200A01-E6               up        up     on
Temperature Info :
    CPU Temperature    MAC Temperature   PHY1 Temperature   PHY2 Temperature
                  33                 36                 29                 34
Power Supply Info :
        Ps#1 Status       : UP
        Ps#1 Type         : AC
        Ps#1 Description  : DPS-800RB D
        Ps#1 Serial Number: GWXD1415000060
        Ps#1 Version      : S1F
        Ps#1 Part Number  : 700508298
        Ps#2 Status       : empty
        Total Power Available : 800 watts
Fan Info :
        Fan#1 Status             : up
        Fan#1 Type               : regularSpeed
        Fan#1 FlowType           : front-back
        Fan#2 Status             : up
        Fan#2 Type               : regularSpeed
        Fan#2 FlowType           : front-back
LED Info :
        LED#1 Label  : PWR
        LED#1 Status : GreenSteady
        LED#2 Label  : Status
        LED#2 Status : GreenSteady
        LED#3 Label  : Rps
        LED#3 Status : Off
        LED#4 Label  : Fan
        LED#4 Status : GreenSteady
System Error Info :
        Send Login Success Trap  : false
        Send Authentication Trap  : false
        Error Code                : 0
        Error Severity            : 0
Port Lock Info :
        Status       : off
        LockedPorts  :
Message Control Info :
        Action                 : suppress-msg
        Control-Interval       : 5
        Max-msg-num            : 5
        Status                 : disable
Configuration Operation Info :
         Last Change: 0 day(s), 00:03:30
    Last Vlan Change: 0 day(s), 00:03:30
Last Statistic Reset: 0 day(s), 00:00:00
Current Uboot Info :
 VU-Boot 2012.04-00002-g6fb1c26 (Apr 26 2017 - 13:51:26) bld=17042617
The following example shows the partial output of the show sys-info command on a VSP 7254XSQ switch. The part number EC720003X-E6 indicates it is a port licensed switch.
Switch:1#show sys-info
General Info :
        SysDescr     : VSP-7254XSQ (w.x.y.z)
        SysName      : SF-237:1
        SysUpTime    : 9 day(s), 00:30:59
        SysContact   : support@extremenetworks.com
        SysLocation  :
Chassis Info:
        Chassis            : 7254XSQ
        Serial#            : 15JP113CF01L
        H/W Revision       : 00
        H/W Config         :
        Part Number        : EC720003X-E6
        NumSlots           : 2
        NumPorts           : 73
        BaseMacAddr        : a4:25:1b:54:9c:00
        MgmtMacAddr        : a4:25:1b:54:9c:81
        System MTU         : 1950
                        The following example shows partial output from the show sys-info command for a VSP4900-12MXU-12XE switch.
General Info :
        SysDescr     : VSP-4900-12MXU-12XE (w.x.y.z)
        SysName      : Switch
        SysUpTime    : 1 day(s), 06:14:14
        SysLocation  :
Chassis Info:
        Chassis            : VSP-4900-12MXU-12XE
        ModelName          : VSP-4900-12MXU-12XE
        BrandName          : Extreme Networks.
        Serial#            : 1924F-10300
        H/W Revision       : 01
        H/W Config         :
        Part Number        : 800977-00-01
        NumSlots           : 2
        NumPorts           : 27
        System MTU         : 1950
Card Info :
        Status  Status  State
  1      VSP4900-12MXU-12XE  19000-10396       800977-00-01           up      up     on
Temperature Info :
              Sensor                  Warning   Critical
         Description   Temperature  Threshold  Threshold
                 CPU            40         78         86
        MAIN BOARD 1            44         57         62
        MAIN BOARD 2            43         59         64
            CPU CORE            32         75         95
                 MAC            69        100        110
                PHY1            41        100        110
                PHY2            40        100        110
                PHY3            43        100        110
                PHY4            50        100        110
                PHY5            53        100        110
                PHY6            53        100        110
Power Supply Info :
        Ps#1 Status       : UP
        Ps#1 Type         : AC
        Ps#1 Description  : Summit 350W AC PSU
        Ps#1 Serial Number: 2400
        Ps#1 Version      : 07
        Ps#1 Part Number  : 800764-00-07
        Ps#2 Status       : empty
        Total Power Available : 350 watts
        Total Power Usage     : 330 watts
Fan Info :
            Description   OperStatus       OperSpeed   AirflowDir
           Tray 1 Fan 1           up        lowSpeed   front-back
           Tray 1 Fan 2           up        lowSpeed   front-back
           Tray 2 Fan 1           up        lowSpeed   front-back
           Tray 2 Fan 2           up        lowSpeed   front-back
           Tray 3 Fan 1           up        lowSpeed   front-back
           Tray 3 Fan 2           up        lowSpeed   front-back
SSD Module Info:
        Product Name      : XN-SSD-001-120
        Vendor Name       : Extreme Networks Inc.
        Manufacture Date  : 09/06/2019 18:16:38
        Serial Num        : 1936F-10000
        Part Num          : 800954-00-AA
        Device Version    : 0
        Total Size        : 120GB
LED Info :
        LED#1 Label  : SYS
        LED#2 Label  : SPD
        LED#2 Status : Off
        LED#3 Label  : STK
        LED#3 Status : Off
        LED#4 Label  : BT
        LED#4 Status : Off
        LED#5 Label  : P1
        LED#5 Status : GreenSteady
        LED#6 Label  : P2
        LED#6 Status : Off
System Error Info :
        Error Code                : 0
        Error Severity            : 0
Port Lock Info :
        Status       : off
        LockedPorts  :
        Max-msg-num            : 5
        Status                 : disable
Configuration Operation Info Since Boot Up:
         Last Change: 0 day(s), 00:01:41   (1 day(s), 06:13:22 ago)
    Last Vlan Change: 0 day(s), 00:00:00
Current FPGA/CPLD Info :
         MODULE                  VERSION
         CPU CPLD                : 1.1.18
         SYSTEM FPGA             : 1.2.41
         PORT1 PLD               : 1.1.08
To display port information for a switch, use the show interfaces gigabitethernet command.
On a VSP 7200 Series switch that is port licensed, use the command show interfaces gigabitethernet to view the licensed status of the ports on the switch.
show interfaces gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
The following example shows output for the show interfaces gigabitethernet 1/41 – 1/42 command. Slot and port information can differ depending on hardware platform. For more information, see your hardware documentation.
Switch:1#show interfaces gigabitEthernet 1/41-1/42 ================================================================================ Port Interface ================================================================================ PORT LINK PORT PHYSICAL STATUS NUM INDEX DESCRIPTION TRAP LOCK MTU ADDRESS ADMIN OPERATE ---------------------------------------------------------------------------------- 1/41 232 40GbNone true false 1950 b0:ad:aa:41:34:28 down down 1/42 233 40GbNone true false 1950 b0:ad:aa:41:34:29 down down
The following example shows the partial output of the show interfaces gigabitethernet command for the VSP 7254XSQ switch. View the LICENSE STATUS field. It can have one of the following values:
n/a: Indicates that it is not a port that is activated by a port license.
locked: Indicates that the port is locked and non-operational because the switch is port licensed and a valid port license is not present.
Attempting to enable a locked port, for example port 1/25, displays the error message Error: port 1/25, Port License is required to enable this port.
unlocked: Indicates that the port is unlocked and is operational, because a valid port license is present.
                                          Port Interface
PORT                        LINK  PORT           PHYSICAL          STATUS         LICENSE
NUM      INDEX DESCRIPTION  TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE STATUS
1/1      192   10GbNone         true  false    1950  a4:25:1b:54:9c:00 up     down    n/a
1/2      193   10GbNone         true  false    1950  a4:25:1b:54:9c:01 down   down    n/a
1/3      194   10GbNone         true  false    1950  a4:25:1b:54:9c:02 down   down    n/a
1/4      195   10GbNone         true  false    1950  a4:25:1b:54:9c:03 down   down    n/a
1/5      196   10GbNone         true  false    1950  a4:25:1b:54:9c:04 down   down    n/a
1/6      197   10GbNone         true  false    1950  a4:25:1b:54:9c:05 down   down    n/a
1/7      198   10GbNone         true  false    1950  a4:25:1b:54:9c:06 down   down    n/a
1/8      199   10GbNone         true  false    1950  a4:25:1b:54:9c:07 down   down    n/a
1/9      200   10GbNone         true  false    1950  a4:25:1b:54:9c:08 down   down    n/a
1/10     201   10GbNone         true  false    1950  a4:25:1b:54:9c:09 down   down    n/a
1/11     202   10GbNone         true  true     1950  a4:25:1b:54:9c:0a up     down    n/a
1/12     203   10GbNone         true  false    1950  a4:25:1b:54:9c:0b down   down    n/a
1/13     204   10GbNone         true  false    1950  a4:25:1b:54:9c:0c down   down    n/a
1/14     205   10GbNone         true  false    1950  a4:25:1b:54:9c:0d up     down    n/a
1/15     206   10GbNone         true  false    1950  a4:25:1b:54:9c:0e up     down    n/a
1/16     207   10GbCX           true  false    1950  a4:25:1b:54:9c:0f up     up      n/a
1/17     208   10GbNone         true  false    1950  a4:25:1b:54:9c:10 down   down    n/a
1/18     209   10GbNone         true  false    1950  a4:25:1b:54:9c:11 down   down    n/a
1/19     210   10GbNone         true  false    1950  a4:25:1b:54:9c:12 down   down    n/a
1/20     211   10GbNone         true  false    1950  a4:25:1b:54:9c:13 down   down    n/a
1/21     212   10GbNone         true  false    1950  a4:25:1b:54:9c:14 up     down    n/a
1/22     213   10GbNone         true  false    1950  a4:25:1b:54:9c:15 up     down    n/a
1/23     214   10GbNone         true  false    1950  a4:25:1b:54:9c:16 down   down    n/a
1/24     215   10GbNone         true  false    1950  a4:25:1b:54:9c:17 up     down    n/a
1/25     216   10GbNone         true  false    1950  a4:25:1b:54:9c:18 down   down    unlocked
1/26     217   10GbNone         true  false    1950  a4:25:1b:54:9c:19 down   down    unlocked
1/27     218   10GbNone         true  false    1950  a4:25:1b:54:9c:1a down   down    unlocked
1/28     219   10GbNone         true  false    1950  a4:25:1b:54:9c:1b down   down    unlocked
1/29     220   10GbNone         true  false    1950  a4:25:1b:54:9c:1c down   down    unlocked
1/30     221   10GbNone         true  false    1950  a4:25:1b:54:9c:1d down   down    unlocked
1/31     222   10GbNone         true  false    1950  a4:25:1b:54:9c:1e down   down    unlocked
1/32     223   10GbNone         true  false    1950  a4:25:1b:54:9c:1f down   down    unlocked
1/33     224   10GbNone         true  false    1950  a4:25:1b:54:9c:20 down   down    unlocked
1/34     225   10GbNone         true  false    1950  a4:25:1b:54:9c:21 down   down    unlocked
1/35     226   10GbNone         true  false    1950  a4:25:1b:54:9c:22 down   down    unlocked
1/36     227   10GbNone         true  false    1950  a4:25:1b:54:9c:23 down   down    unlocked
1/37     228   10GbNone         true  false    1950  a4:25:1b:54:9c:24 down   down    unlocked
1/38     229   10GbNone         true  false    1950  a4:25:1b:54:9c:25 down   down    unlocked
1/39     230   10GbNone         true  false    1950  a4:25:1b:54:9c:26 down   down    unlocked
1/40     231   10GbNone         true  false    1950  a4:25:1b:54:9c:27 down   down    unlocked
1/41     232   10GbNone         true  false    1950  a4:25:1b:54:9c:28 down   down    unlocked
1/42     233   10GbNone         true  false    1950  a4:25:1b:54:9c:29 down   down    unlocked
1/43     234   10GbNone         true  false    1950  a4:25:1b:54:9c:2a down   down    unlocked
1/44     235   10GbNone         true  false    1950  a4:25:1b:54:9c:2b down   down    unlocked
1/45     236   10GbNone         true  false    1950  a4:25:1b:54:9c:2c down   down    unlocked
1/46     237   10GbNone         true  false    1950  a4:25:1b:54:9c:2d down   down    unlocked
1/47     238   10GbNone         true  false    1950  a4:25:1b:54:9c:2e down   down    unlocked
1/48     239   10GbNone         true  false    1950  a4:25:1b:54:9c:2f down   down    unlocked
2/1      256   40GbNone         true  false    1950  a4:25:1b:54:9c:40 up     down    n/a
2/2      260   40GbNone         true  false    1950  a4:25:1b:54:9c:44 down   down    n/a
2/3      264   40GbNone         true  false    1950  a4:25:1b:54:9c:48 down   down    n/a
2/4      268   40GbNone         true  false    1950  a4:25:1b:54:9c:4c down   down    n/a
2/5/1    272   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:50 down   down    unlocked
2/5/2    273   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:51 down   down    unlocked
2/5/3    274   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:52 down   down    unlocked
2/5/4    275   40GbNone-Channel true  false    1950  a4:25:1b:54:9c:53 down   down    unlocked
2/6      276   40GbNone         true  false    1950  a4:25:1b:54:9c:54 down   down    unlocked
