Viewing OSPF status
View OSPF status.
- Click OSPF.
- Click the Stats tab.
Viewing OSPF status graphs
View OSPF status graphs. The graph formats available are: line chart, area chart, bar chart, and pie chart.
Stats field descriptions
Use the data in the following table to use the OSPF Stats tab.
Name |
Description |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the Stats tab. |
Average/sec |
Displays the average value for each second. |
Minimum/sec |
Displays the minimum value for each second. |
Maximum/sec |
Displays the maximum value for each second. |
LastVal/sec |
Displays the last value for each second. |
LsdbTblSize |
Displays the number of entries in the link state database table. |
TxPackets |
Displays the number of packets transmitted by OSPF. |
RxPackets |
Displays the number of packets received by OSPF. |
TxDropPackets |
Displays the number of packets dropped before transmitted by OSPF. |
RxDropPackets |
Displays the number of packets dropped before received by OSPF. |
RxBadPackets |
Displays the number of packets received by OSPF that are bad. |
SpfRuns |
Displays the total number of SPF calculations performed by OSPF, which includes the number of partial route table calculation for incremental updates. |
BuffersAllocated |
Displays the number of buffers allocated for OSPF. |
BuffersFreed |
Displays the number of buffers that are freed by the OSPF. |
BufferAllocFailures |
Displays the number of times that OSPF has failed to allocate buffers. |
BufferFreeFailures |
Displays the number of times that OSPF has failed to free buffers. |
Routes |
Displays the number of OSPF routes added to RTM. |
Adjacencies |
Displays how many adjacencies are learned through the interface. |
Areas |
Displays the number of areas configured. |
Nbrs |
Indicates the number of OSPF neighbors. |
BadLsReqs |
Indicates the number of bad link state requests. |
SeqMismatches |
Indicates the number of sequence mismatched packets. |
NumAllocDDP |
Indicates the number of database description (DD) packet buffers allocated for OSPF. |
NumFreeDDP |
Indicates the number of DD packet buffers that are freed by the OSPF. |
