Viewing IPv6 VRRP Statistics
View IPv6 VRRP statistics to monitor network performance
View IPv6 VRRP statistics for VRID 1.
Switch:1(config)#show ipv6 vrrp statistics vrid 1
VRRP Interface Stats - GlobalRouter
VRID P/V BECOME_MASTER ADVERTISE_RCV
1 84 2 17372
1 85 2 17372
1 86 1 0
1 87 1 0
1 1001 2 17372
VRID P/V ADVERTISE_INT_ERR TTL_ERR PRIO_0_RCV
1 84 0 0 0
1 85 0 0 0
1 86 0 0 0
1 87 0 0 0
1 1001 0 0 0
VRID P/V PRIO_0_SENT INVALID_TYPE_ERR ADDRESS_LIST_ERR UNKNOWN_AUTHTYPE
--More-- (q = quit)
Use the data in the following table to use the show ipv6 vrrp statistics command.
Variable |
Value |
link-local WORD<0–127> |
Shows statistics for a specific link-local address. |
vrid <1–255> |
Shows statistics for a specific VRID. |
Job Aid
The following table describes the output for the show ipv6 vrrp statistics command.
Heading |
Description |
CHK_SUM_ERR |
Shows the number of VRRP packets received with an invalid VRRP checksum value. |
VERSION_ERR |
Shows the number of VRRP packets received with an unknown or unsupported version number. |
VRID_ERR |
Shows the number of VRRP packets received with an invalid VrID for this virtual router. |
BECOME_MASTER |
Shows the total number of times that the state of this virtual router has transitioned to master. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
ADVERTISE_RCV |
Shows the total number of VRRP advertisements received by this virtual router. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
ADVERTISE_INT_ERR |
Shows the total number of VRRP advertisement packets received for which the advertisement interval is different than the one configured for the local virtual router. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
TTL_ERR |
Shows the total number of VRRP packets received by the virtual router with IPv4 TTL (for VRRP over IPv4) or IPv6 Hop Limit (for VRRP over IPv6) not equal to 255. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
PRIO_0_RCV |
Shows the total number of VRRP packets received by the virtual router with a priority of 0. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
PRIO_0_SENT |
Shows the total number of VRRP packets sent by the virtual router with a priority of 0. Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
INVALID_TYPE_ERR |
Shows the number of VRRP packets received by the virtual router with an invalid value in the 'type' field. Discontinuities in the value of this counter can occur at reinitialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
ADDRESS_LIST_ERR |
Shows the total number of packets received for which the address list does not match the locally configured list for the virtual router. Discontinuities in the value of this counter can occur at reinitialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
UNKNOWN_AUTHTYPE |
Shows the total number of packets received with an unknown authentication type. |
PACKLEN_ERR |
Shows the total number of packets received with a packet length less than the length of the VRRP header. Discontinuities in the value of this counter can occur at reinitialization of the management system, and at other times as indicated by the value of DiscontinuityTime. |
