Perform a general VLAN action to initiate a specific function on a VLAN, such as clearing learned MAC addresses or ARP entries from the forwarding database by performing this procedure.
Perform a general VLAN action:
Switch(config)# vlan action 1 none
Switch(config)# vlan action 1 flushMacFdb
Switch(config)# vlan action 1 flushIp
Switch(config)# vlan action 1 flushDynMemb
Variable definitions
Use the data in the following table to use the vlan action command.
Variable |
Value |
none |
Configures action to none. This action performs no updates. |
flushMacFdb |
Configures action to flushMacFdb. This action removes the learned MAC addresses from the forwarding database for the selected VLAN. |
flushArp |
Configures action to flushArp. This action removes the ARP entries from the address table for the selected VLAN. |
flushIp |
Configures action to flushIp. This action removes the learned IP addresses from the forwarding table for the selected VLAN. |
flushDynMemb |
Configures action to flushDynMemb. This action removes port members not configured as static from the list of active port members of a policy-based VLAN, and removes MAC addresses learned on those ports for this VLAN. |
flushDynMemb |
triggerRipUpdate |
Configures action to triggerRipUpdate. |
all |
Configures action to all and performs all preceding actions. |
