Use this procedure to view FA statistics.
- Click Fabric Attach.
- In the content pane, click the Stats tab.
Stats field descriptions
Use the data in the following table to use the Stats tab.
| Name | Description |
| PortIndex | Specifies the port for which the FA statistics are displayed. |
| DiscElemReceived | Specifies the number of element discoveries received on the port. |
| AsgnReceived | Specifies the number of remote assignments received on the port. |
| AsgnAccepted | Specifies the number of remote assignments accepted on the port. |
| AsgnRejected | Specifies the number of remote assignments rejected on the port. |
| AsgnExpired | Specifies the number of remote assignments that have expired, on the port. |
| AuthFailed | Specifies the number of authentications that have failed on the port. |
| DiscElemExpired | Specifies the number of discovery elements that have expired on the port. |
| DiscElemDeleted | Specifies the number of discovery elements that are deleted on the port. |
| AsgnDeleted | Specifies the number of remote assignments deleted on the port. |
| AsgnAuthFailed | Specifies the number of remote assignment authentications that failed on the port. |
