Use Secure Shell version 2 (SSHv2) to enable secure communications support over a network for authentication, encryption, and network Integrity.
Disable the sshd daemon. All SSHv2 commands, except enable, require that you disable the sshd daemon.
Set the user access level to read/write/all community strings.
Disable all nonsecure access services. As a best practice, disable the following services: Trivial File Transfer Protocol (TFTP), File Transfer Protocol (FTP), Telnet, and Remote login (rlogin). For more information about disabling access services, see Enable Remote Access Service.
Rlogin is only supported on VSP 8600 Series.
Use the console port to configure the SSHv2 parameters. Depending on your hardware platform, the console port displays as console or 10101.
