View MSTP MSTI information to ensure the feature is configured correctly for your network.
Show MSTI information:
Switch:1>
show spanning-tree mstp msti config
62
MSTP Instance Status
Instance Id : 62
Msti Bridge Regional Root : 80:00:00:15:e8:9e:10:01
Msti Bridge Priority : 32768 (0x8000)
Msti Root Cost : 0
Msti Root Port : cpp
Msti Instance Vlan Mapped :
Msti Instance Vlan Mapped2k :
Msti Instance Vlan Mapped3k :
Msti Instance Vlan Mapped4k : 4000
Switch(config)#
show spanning-tree mstp msti port statistics
1/1
MSTP Instance-specific Per-Port Statistics
Port Number : 1/1
Instance Id : 1
Msti Port Fwd Transitions : 0
Msti Port Received BPDUs : 0
Msti Port Transmitted BPDUs : 0
Msti Port Invalid BPDUs Rcvd : 0
Use the data in the following table to use the show spanning-tree mstp msti command.
Variable |
Value |
config [<1-63>] |
Shows the configuration for one or all MSTP instance IDs. |
port |
Shows the configuration, role, or statistics information of a MSTP port.
