Create a port-based VLAN.
Use the following procedure to enable Universal Plug and Play (uPnP) Filtering on an IGMP-enabled interface. uPnP Filtering is disabled by default.
The default uPnP Filtering multicast group address range is 239.255.255.250/32. If you do not configure the multicast group range, uPnP Filtering filters multicast packets destined for the default multicast group range.
Enable uPnP Filtering on a VLAN using the default multicast group address range:
Switch:1(config-if)#ip igmp upnp-filter
Enable uPnP Filtering on a VLAN with configured multicast group address range:
Switch:1(config-if)#ip igmp upnp-filter ip 233.252.0.0/24
Variable definitions
The following table defines parameters for the ip igmp upnp-filter command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
ip {A.B.C.D/X} |
Configures the multicast destination IP address range to filter for an IGMP interface. The default multicast group address is 239.255.255.250/32. |
vlan <1-4059> |
Specifies the VLAN. |
