Use the following procedure to view a summary of SPBM and IS-IS protocol information.
- Click IS-IS.
- Click the Protocol Summary tab.
Protocol Summary field descriptions
Use the data in the following table to use the Protocol Summary tab.
| Name | Description |
| Globals ISIS | |
| AdminState | Indicates the global status of IS-IS on the switch. |
| SystemId | Indicates the IS-IS system ID for the switch. Valid value is a 6–byte value in the format <xxxx.xxxx.xxxx> |
| HostName | Indicates a name for the system. This may be used as the host name for dynamic host name exchange in accordance with RFC 2763. By default, the system name comes from the host name configured at the system level. |
| Globals SPBM | |
| GlobalEnable | Indicates whether SPBM is enabled or disabled at the global level. |
| NodeNickName | Indicates the nickname for the SPBM instance globally. Valid value is 2.5 bytes in the format <x.xx.xx>. |
| PrimaryVlan | Indicates the primary VLAN ID for this SPBM instance. |
| SmltSplitBEB | Indicates whether the switch is the primary or secondary IST peer. |
| ISIS Interfaces | |
| Circuit Index | Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This is for SNMP Indexing purposes only and need not have any relation to any protocol value. |
| IfIndex | Indicates the interface to which this circuit corresponds. |
| AdminState | Indicates the administrative state of the circuit: on or off. |
| OperState | Indicates the operational state of the circuit: up or down. |
| ISIS Adjacency View | |
| Circuit Index | Displays the identifier of this IS-IS circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value. |
| AdjIndex | Displays a unique value identifying the IS adjacency from all other such adjacencies on this circuit. This value is automatically assigned by the system when the adjacency is created |
| AdjIfIndex | Indicates the interface to which this circuit corresponds. |
| AdjState | Indicates the state of the adjacency:
| AdjNeighSysID | Indicates the system ID of the neighboring Intermediate System. |
| AdjHostName | Indicates the host name listed in the LSP, or the system name if the host name is not configured. |
