Configure the system log to track all user activity on the device. The system log can send messages of up to ten syslog hosts.
- Click System Log.
- In the System Log tab, select Enable.
- Configure the maximum number of syslog hosts.
- Configure the IP header type for the syslog packet.
- Click Apply.
System Log Field Descriptions
Use the data in the following table to use the System Log tab.
| Name | Description |
| Enable | Enables or disables the syslog feature. If you select this variable, this feature sends a message to a server on a network that is configured to receive and store diagnostic messages from this device. You can configure the type of messages sent. The default is enabled. |
| MaxHosts | Specifies the maximum number of remote hosts considered active and can receive messages from the syslog service. The range is 0–10 and the default is 5. |
| OperState | Specifies the operational state of the syslog service. The default is active. |
| Header | Specifies the IP header in syslog packets to circuitlessIP or default.
 The default value is default. |
