Enabling the Gateway
Enable the Gateway at the global (switch-wide) level.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#spbm 1 multicast spb-pim-gw gateway enable
Variable definitions
The following table defines parameters for the spb command.
| Variable | Value |
| <1-100> | Specifies the isis spbm instance-id to create the spbm instance. |
| gateway enable | Enables the SPB-PIM Gateway. |
