Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
Display extended OSPF information:
Switch:1>enable
Switch:1#show ports statistics ospf extended
                            Port Stats Ospf Extended
PORT_NUM RXLS_REQS  TXLS_REQS  RXLS_ACKS  TXLS_ACKS
1/3      0          0          0          0
Use the data in the following table to use the show ports statistics ospf extended command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
Job Aid
The following table describes the output for the show ports statistics ospf extended command.
 Parameters  |
 Description  |
 PORT_NUM  |
 Indicates the port number.  |
 RXLS_REQS  |
 Indicates the number of link state update request packets received by this interface.  |
 TXLS_REQS  |
 Indicates the number of link state request packets transmitted by this interface.  |
 RXLS_ACKS  |
 Indicates the number of link state acknowledge packets received by this interface.  |
 TXLS_ACKS  |
 Indicates the number of link state acknowledge packets transmitted by this interface.  |
