This procedure does not apply to VSP 8600 Series.
Use this task to view TCP connections and UDP endpoints statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 Socket (TCP/UDP) tab.
IP/IPv6 Socket (TCP/UDP) Field Descriptions
Use the data in the following table to use the IP/IPv6 Socket (TCP/UDP) tab.
| Name | Description |
| IPVersion | Shows the IP address version as ipv4 or ipv6. |
| Type | Shows the connection type as tcp or udp. |
| Index | Shows the index ID for the connection. |
| State | Shows the link state for the connection. |
| RecvQ | Shows the connection received quanitity. |
| SendQ | Shows the connection sent quantity. |
| LocalAddressAndPort | Shows the local IP address and port. |
| PeerAddressAndPort | Shows the peer IP address and port. |
