Configure a tagged port to discard all untagged packets so that the frame is not classified into the default VLAN for the port.
Configure a tagged port to discard untagged frames:
Switch(config-if)#untagged-frames-discard port 1/1
Discard a tagged frame on an untagged port:
Switch(config-if)#tagged-frames-discard port 1/1 enable
Untag the default VLAN on a tagged port:
Switch(config-if)#untag-port-default-vlan port 1/2 enable
Variable definitions
Use the data in the following table to use optional parameters with the untagged-frames-discard command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
