Feature |
Product |
Release introduced |
| For configuration details, see VOSS User Guide. | ||
Zero Touch Provisioning Plus |
5520 Series |
VOSS 8.2.5 |
VSP 4450 Series |
VOSS 8.2.5 |
VSP 4900 Series |
VOSS 8.2.5 |
VSP 7200 Series |
VOSS 8.2.5 |
VSP 7400 Series |
VOSS 8.2.5 |
VSP 8200 Series |
VOSS 8.2.5 |
VSP 8400 Series |
VOSS 8.2.5 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
VOSS 8.2.5 |
With zero touch functionality, VOSS switches are automatically discovered on the network the moment they are connected.
Zero Touch Provisioning Plus (ZTP+) enables you to deploy and configure VOSS switches in Extreme Management Center with minimal server configuration and intervention. ZTP+ enabled switches send information, such as the serial number, software version, MAC, management IP, and port information to Extreme Management Center automatically.
When the switch powers on, the DHCP Client obtains the IP address and gateway from the DHCP server, discovers the Domain Name Server, and connects the switch to Extreme Management Center.
ZTP+ uses HTTPS for communication between the switch and the Extreme Management Center server. The switch discovers the Extreme Management Center server by resolving the DNS name extremecontrol.<domain-name>.
Important
This feature requires a Zero Touch Deployment-ready configuration. For more information, see Zero Touch Deployment.
