Use the following procedure to display the IPv6 unicast Forwarding Information Base (FIB). The tab shows IPv6 routes from remote Backbone Edge Bridges (BEBs)
In SPBM, each node has a System ID, which also serves as Backbone MAC address (B-MAC) of the switch. These Backbone MAC addresses are populated into the SPBM VLAN Forwarding Information Base (FIB). When the network topology is discovered and stored in the IS-IS link-state database, each node calculates shortest path trees for each source node, so that a unicast path now exists from every node to every other node. With this information, each node populates unicast information received from SPBM into the FIB for forwarding purposes.
I-SIDs are only used for virtual services (Layer 2 VSNs and Layer 3 VSNs). If you only enable IP Shortcuts on the Backbone Edge Bridges, I-SIDs are never exchanged in the network as IP Shortcuts allows for Global Routing Table (GRT) IP networks to be transported across IS-IS.
- Click SPBM.
- Click the IPv6 Unicast FIB tab.
IPv6 Unicast FIB Field Descriptions
Use the data in the following table to use the IPv6 Unicast FIB tab.
Name |
Description |
VrfId |
Specifies the VRF ID of the IPv6 unicast FIB entry, 0 indicates NRE. |
DestinationIpAddrType |
Specifies the address type of the destination IPv6 address. |
DestinationIpAddr |
Specifies the destination IPv6 Address of the IPv6 unicast FIB entry. |
DestinationMask |
Specifies the destination IPv6 mask of the IPv6 unicast FIB entry |
NextHopBmac |
Specifies the nexthop B-MAC of the IPv6 unicast FIB entry. |
DestIsid |
Specifies the destination I-SID of the IPv6 unicast FIB entry. |
Vlan |
Specifies the VLAN of the IPv6 unicast FIB entry. |
Isid |
Specifies the I-SID of the IPv6 unicast FIB entry. |
NextHopName |
Specifies the nexthop hostname of the IPv6 unicast FIB entry. |
OutgoingPort |
Specifies the outgoing port of the IPv6 unicast FIB entry. |
PrefixCost |
Specifies the prefix cost of the IPv6 unicast FIB entry. |
SpbmCost |
Specifies the B-MAC cost of the IPv6 unicast FIB entry. |
MetricType |
Specifies the Metric Type of the IPv6 unicast FIB entry. |
