The 25 GbE ports typically support 25 Gbps, 10 Gbps, and 1 Gbps operational speeds. Auto-Negotiation support varies depending on the pluggable type and speed.
The following table provides a summary of Auto-Negotiation support for 25 Gbps ports.
                             Transceiver Type  |
                             Auto-Negotiation  |
                             25 Gbps DAC  |
                             Supported Note:
                        Exception: VIM5-2Y and VIM5-4Y do not support Auto-Negotiation at 25 Gbps.  |
                             25 Gbps SR, LR, AOC  |
                             Not Supported  |
                             10 Gbps  |
                             Not Supported  |
                             1 Gbps  |
                             Note:
                        Not Supported for VSP 7400-48Y.  |
Forward Error Correction (FEC) is a negotiated port attribute for 25 GbE connections that support Auto-Negotiation. For more information, see Forward Error Correction.
