Configuring the logon banner
Configure the logon banner to display a warning message to users before authentication.
Switch:1> enable
Switch:1# configure terminal
Activate the use of the default banner:
Switch:1(config)# banner static
The following table defines parameters for the banner command.
 Variable  |
 Value  |
 custom|static  |
 Activates or disables use of the default banner.  |
                             displaymotd  |
 Enables displaymotd.  |
                             motd  |
 Sets the message of the day banner.  |
 WORD<1–80>  |
 Adds lines of text to the CLI logon banner.  |
