Perform this procedure to view the I-SID bridge forwarding database.
The show i-sid mac-address-entry command displays the C-MACs learned on T-UNI I-SIDs. It also displays the C-MACs learned on T-UNI I-SIDs for a specific I-SID, MAC address, port or port list or remote MAC address.
View C-MACs learned on all T-UNI I-SIDs.
Switch:1#show i-sid mac-address-entry
I-SID Fdb Table
I-SID STATUS MAC-ADDRESS INTERFACE TYPE DEST-MAC BVLAN DEST-SYSNAME
100 learned cc:f9:54:ae:28:81 Port-1/16 LOCAL 00:00:00:00:00:00 0
4 learned cc:f9:54:ae:2c:18 mlt-6 LOCAL 00:00:00:00:00:00 0
252 learned cc:f9:54:ae:38:64 Port-1/15 REMOTE 00:13:0a:0c:d3:e0 128 DIST-1B
All 3 out of 3 Total Num of i-sid FDB Entries displayed
View C-MACs learned on a specific T-UNI I-SID.
Switch:1#show i-sid mac-address-entry 100
I-SID Fdb Table
All 1 out of 1 Total Num of i-sid FDB Entries displayed
Switch:1#show i-sid mac-address-entry 252
I-SID Fdb Table
View C-MACs learned on a T-UNI I-SID for a specific MAC address.
Switch:1#show i-sid mac-address-entry mac cc:f9:54:ae:38:64
I-SID Fdb Table
View C-MACs learned on aT-UNI I-SID for a specific port.
Switch:1#show i-sid mac-address-entry port 1/15
I-SID Fdb Table
View C-MACs learned on a T-UNI I-SID as a remote MAC address.
Switch:1#show i-sid mac-address-entry remote
I-SID Fdb Table
The following table defines parameters for the show i-sid mac-address-entry command.
Variable |
Value |
<1-16777215> |
Displays the MAC address learned on the service interface identifier (ISID). |
mac <0x00:0x00:0x00:0x00:0x00:0x00> |
Displays the I-SID FDB details for the specified MAC address. |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Displays the MAC address learned on the specified port or port list. |
remote |
Displays the remote MAC address learned on the I-SID. |
Job Aid
The following table describes the fields in the output for the show i-sid mac-address-entry command.
Field |
Description |
I-SID |
Specifies the service interface identifier (I-SID). |
STATUS |
Specifies the learning status of the associated MAC. |
MAC-ADDRESS |
Specifies the MAC address of the port assigned to the specific I-SID or MAC learned on the specific I-SID. |
INTERFACE |
Specifies the port or MLT on which the MAC is learned for the specific I-SID. |
TYPE |
Specifies whether the MAC is a Local or IST PEER or a Remote MAC. |
DEST-MAC |
Specifies the virtual BMAC address or system ID, in MAC format, of the destination node. |
BVLAN |
Specifies the BVLAN on which the destination node is discovered for the I-SID. |
DEST-SYSNAME |
Specifies the destination system name. |
