Use the following commands to display IGMP information.
enable
show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>][vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the ouput displays routed-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
Display IGMP information for IP multicast over Fabric Connect within the GRT:
Switch:1#show ip igmp interface
                         Igmp Interface - GlobalRouter
       QUERY              OPER            QUERY   WRONG              LASTMEM
IF     INTVL STATUS VERS. VERS QUERIER    MAXRSPT QUERY JOINS ROBUST QUERY   MODE   L2ISID
V100   125    activ  2     2   0.0.0.0    100     0     0     2      10      snoop-spb 1100
1 out of 1 entries displayed
               Switch:(config)#show ip igmp interface vlan 2
                                  Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST  PROXY  SNOOP  SSM    UPnP   FAST   FAST
ID   INTVL MAX                  MEMB  SNOOP  ENABLE SNOOP  FILTER LEAVE  LEAVE
           RESP                 QUERY ENABLE        ENABLE ENABLE ENABLE PORTS
2    125   100   2      2       10    false  false  false  false  false
VLAN SNOOP   SNOOP           DYNAMIC   COMPATIBILITY EXPLICIT UPnP
ID   QUERIER QUERIER         DOWNGRADE MODE          HOSTS    FILTER
     ENABLE  ADDRESS         VERSION                 TRACKING ADDRESS
2    false   0.0.0.0         enable    disable       disable  239.255.255.250/32
Switch:1# show ip igmp sender
                           IGMP Sender - GlobalRouter
                                           PORT/
GRPADDR         IFINDEX    MEMBER          MLT        STATE
233.252.0.1    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.2    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.3    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.4    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.5    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.6    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.7    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.8    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.9    Vlan 501   192.2.0.1      9/16        NOTFILTERED
233.252.0.10   Vlan 501   192.2.0.1      9/16        NOTFILTERED
10 out of 10 entries displayed
Switch:1# show ip igmp group
                           IGMP Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE
233.252.0.1    V501-9/16       192.2.0.1      204        Dynamic
233.252.0.2    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.3    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.4    V501-9/16       192.2.0.1      207        Dynamic
233.252.0.5    V501-9/16       192.2.0.1      204        Dynamic
233.252.0.6    V501-9/16       192.2.0.1      209        Dynamic
233.252.0.7    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.8    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.9    V501-9/16       192.2.0.1      211        Dynamic
233.252.0.10   V501-9/16       192.2.0.1      207        Dynamic
10 out of 10 group Receivers displayed
Total number of unique groups 10
