Use this procedure to view port EAPoL operation statistics.
Use the clear-stats command to clear EAP/NEAP statistics.
Not all fields are supported on all hardware platforms.
Switch:1(config)#show eapol status interface
Eap Oper Status
PORT MAC STATE VLAN PRI Flex-UNI I-SID VLAN:I-SID
NUM ID Enable SOURCE AUTH
1/1 18:a9:05:b1:04:ce authenticated 10 2 true radius 0:1015
Total Number of EAP Sessions: 1
Switch:1(config-if)#show eapol status interface gigabitEthernet 2/1,2/11 verbose
Eap Oper Status Verbose
PORT MAC PAE VLAN PRI Flex-UNI I-SID VLAN:I-SID ACL ACEs
NUM STATUS ID Enable SOURCE
2/1 00:00:02:eb:34:e9 authenticated N/A 0 true radius 111:10111 2 2,3
2/1 00:00:02:eb:34:eb authenticated N/A 0 true radius 111:10111 2 1
2/1 00:00:02:eb:34:ed authenticated 333 0 true n/a 2 4
2/1 00:00:02:eb:34:ef authenticated 444 0 true n/a 2 5
2/11 00:00:00:06:a9:df authenticated 11 0 true n/a 1 1
2/11 00:00:00:06:a9:e1 authenticated N/A 0 true radius 111:10111
2/11 00:00:00:06:a9:e3 authenticated 33 0 true n/a 1 2
2/11 00:00:00:06:a9:e5 authenticated 44 0 true n/a 1 3
Total Number of EAP sessions : 8
Use the data in the following table to use the show eapol status command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
<1-4059> |
Specifies the VLAN ID for which to show the statistics. |
verbose Note:
Exception: Not supported on VSP 4450 Series, XA1400 Series, or VSP 8600 Series |
Displays detailed statistics information. |
Job Aid
The following table describes the output for the show eapol status interface command.
Parameter |
Description |
PORT NUM |
Displays the port number in use. |
MAC |
Displays the MAC address of the client. |
PAE STATUS |
Indicates the current state of the authenticator PAE state machine. |
VLAN ID |
Indicates the VLAN assigned to the client. |
PRI |
Indicates port priority. |
Flex-UNI Enable Note:
Indicates the Flex-UNI status. |
I-SID SOURCE Note:
Exception: Not supported on XA1400 Seriesor VSP 8600 Series |
Indicates the I-SID source. |
VLAN:I-SID Note:
Indicates the VLAN to I-SID bindings. |
ACL Note:
Indicates access-control list. Note:
This column is visible only when you use the optional verbose parmeter in the command. |
ACEs Note:
Indicates access-control entries. Note:
