Displays DHCPv6 Guard policy information for all the configured DHCPv6 Guard policies or a particular policy.
Switch:1# show ipv6 fhs dhcp-guard policy
IPv6 DHCP Guard Policy Info
POLICY-NAME SERVER-ACC-LIST REPLY-PREF-LIST MIN-RTR-PREF MAX-RTR-PREF
dhcp_pol1 v6_acl1 v6_acl2 0 0
All 1 out of 1 Total Num of dhcp-guard stats entries displayed
The following table defines parameters for the show ipv6 dhcp-guard policy command.
Variable |
Description |
WORD<1–64> |
Displays DHCPv6 Guard policy information for all the configured DHCPv6 Guard policies. Policy name is an optional parameter. If policy name is provided, only the DHCPv6 Guard policy of the specified policy-name is displayed. |
Job Aid
The following table shows the field descriptions for the show ipv6 dhcp-guard policy command.
Field |
Description |
POLICY-NAME |
Indicates the DHCPv6 Guard policy name. |
SERVER-ACC-LIST |
Indicates if the received DHCPv6 server packet source IPv6 addresss matches the configured IPv6 access list. |
REPLY-PREF-LIST |
Indicates if the advertised prefix in received DHCPv6 server packet matches the configured IPv6 access list. |
MIN-RTR-PREF |
Indicates the advertised router preference minimum limit. |
MAX-RTR-PREF |
Indicates the advertised router preference maximum limit. |
