Use the show ipv6 mroute route command to display the IPv6 mroute route information. The syntax for this command is as follows.
Switch:1(config)#show ipv6 mroute route
Mroute Route - GlobalRouter
GROUP SOURCE SRCMASK
UPSTREAM_NBR IF EXPIR PROT
ff30:0:0:0:0:0:0:1 5010:0:0:0:0:1:82:10 64
0:0:0:0:0:0:0:0 VLAN 10 202 pimsm
ff30:0:0:0:0:0:0:1 5010:0:0:0:0:1:82:11 64
0:0:0:0:0:0:0:0 VLAN 10 175 pimsm
2 out of 2 total mroute entries displayed
The following table shows the field descriptions for this command.
Field |
Description |
GROUP |
Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface. |
SRCMASK |
Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
UPSTREAM_NBR |
Shows the address of the upstream neighbor from which the IPv6 datagrams from these sources are received. |
SOURCE |
Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
IF |
Displays the slot and port number or VLAN ID for this entry. |
EXPIR |
Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging. |
PROT |
Displays the protocol as one of the following:
