You can determine the database used by the SPBM multicast module by using the following procedure.
Show the SPBM multicast database:
Switch(config)#show isis spbm ip-multicast-route
                        SPBM IP-MULTICAST FIB ENTRY INFO
Source          Group           Data ISID  BVLAN Source-BEB
192.2.0.1       233.252.0.246        16000001  101   EVP
 Total Number of SPBM IP MULTICAST ROUTE Entries: 1
The following table defines parameters for the show isis spbm ip-multicast-route command.
 Variable  |
 Value  |
 all  |
 Displays all IP Multicast over Fabric Connect route information.  |
 detail  |
 Displays detailed IP Multicast over Fabric Connect route information.  |
 group {A.B.C.D} source {A.B.C.D}  |
 Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address.  |
 vlan <2–4059>  |
 Displays IP Multicast over Fabric Connect route information by VLAN.  |
 vrf WORD<0–16>  |
 Displays IP Multicast over Fabric Connect route information by VRF.  |
 vsn-isid <1–16777215>  |
 Displays IP Multicast over Fabric Connect route information by I-SID.  |
Job Aid
The following table describes fields for the show isis spbm ip-multicast-route command.
 Field  |
 Description  |
 Source  |
 Specifies the IP address of the Global Routing Table.  |
 Group  |
 Specifies the IP multicast group for which this entry specifies a next hop on an outgoing interface.  |
 Data ISID  |
 Specifies the VRF ID for the multicast route.  |
 BVLAN  |
 Specifies the Backbone VLAN (B-VLAN).  |
 Source-BEB  |
 Specifies the source Backbone Edge Bridge (BEB).  |
 Total number of SPBM IP_MULTICAST Route entries  |
 Specifies the number of SPBM IP multicast route entries.  |
