Use this procedure to configure the autogenerated CFM MEP and MIP level for every C-VLAN on the chassis.
For C-VLANs, you can only use autogenerated CFM MEPs.
Important
CFM supports one MEP or MIP for each C-VLAN. Only autogenerated CFM provides support for configuring MEP and MIPs on C-VLANs. You cannot explicitly configure C-VLANs.
When you enable this feature, you create a global MD (named cmac) for all the customer MAC (C-MAC) MEPs. This global MD has a default maintenance level of 4, which you can change with the level attribute. The autogenerated CFM commands also create an MA for each C-VLAN, a MEP for each C-VLAN, associate the MEP with the corresponding C-VLAN, and a MIP with the C-VLAN.
All the MEPs that the device creates use the MEP ID configured under the global context, which has a default value of 1. The device automatically associates the MEPs with the C-VLANs configured. The MIP level maps to the global level. The device automatically associates the MIP level with the C-VLANs configured when you enable the feature.
The feature is disabled by default.
Configure autogenerated CFM MEPs and MIP level:
Switch>enable Switch#configure terminal Switch(config)#cfm cmac level 0 Switch(config)#cfm cmac mepid 4 Switch(config)#cfm cmac enable Switch(config)#show cfm cmac LEVEL ADMIN MEPID MAC ====================================== 0 enable 4 00:15:e8:b8:a3:de
The following table defines parameters for the cfm cmac command.
Variable |
Value |
level<0-7> |
Specifies the global C-MAC CFM maintenance level for the chassis within the range of 0 to 7. The default is 4. Only configure global CFM at one MD level for each chassis for each VLAN type. |
mepid<1-8191> |
Specifies the global MEP ID within the range of 1–8191. Select a unique ID for each switch to ensure that the MEPs are unique across the network. The default is 1. Note:
The MA takes its name from this value for autogenerated CFM. For example, if you specify 500 as the MEP ID, the MA will also be 500. |
enable |
Enables autogenerated CFM for all C-MAC VLANs. |
Job Aid
The following table describes the fields for the show cfm cmac command.
Parameter |
Description |
LEVEL |
Specifies the global C-VLAN CFM maintenance level for the chassis. The default is 4. |
ADMIN |
Specifies if CFM C-VLAN MEPs and MIPs are globally enabled. |
MEP ID |
Specifies the global MEP ID. The default is 1. |
MAC |
Specifies the MAC address. |
