Viewing VLAN information
View the VLAN information to display the basic configuration for all VLANs or a specified VLAN.
View VLAN information for VLAN 2:
Switch:1> show vlan basic 2
                                   Vlan Basic
VLAN                              INST
ID    NAME             TYPE         ID  PROTOCOLID SUBNETADDR      SUBNETMASK   VRFID
2     VLAN-2          byPort       0   none       N/A             N/A		   0
 View VLAN information:
                                   Vlan Basic
VLAN                              INST
1     Default          byPort       0   none       N/A             N/A		  0
2     abc              byPort       0   none       N/A             N/A		  0
3     VLAN-VRRP        byPort       0   none       N/A             N/A		  0
4     VLAN-6           byPort       0   none       N/A             N/A		  1
5     VLAN-7           byPort       0   none       N/A             N/A		  1
6     VLAN-8           byPort       0   none       N/A             N/A		  1
19    VLAN-9           byPort       0   none       N/A             N/A		  0
10    VLAN-10          byPort       0   none       N/A             N/A		  0
11    VLAN-11          byPort       0   none       N/A             N/A		  0
12    VLAN-12          byPort       0   none       N/A             N/A		  0
13    VLAN-13          spbm-bvlan   62  none       N/A             N/A		  0
14    VLAN-14          spbm-bvlan   62  none       N/A             N/A		  0
15    VLAN-15          byPort       1   none       N/A             N/A		  0
--More-- (q = quit)
 View advanced parameters:
Switch:1> show vlan advance
                                  Vlan Advance
VLAN             IF    AGING MAC                USER
ID    NAME       INDEX TIME  ADDRESS            DEFINEPID ENCAP  DSAP/SSAP
2     Default 2050  0     00:24:7f:9f:6a:03  0x0000
 Variable definitions
Use the data in the following table to use optional parameters with the show vlan basic and show vlan advance commands.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
