This section identifies considerations and restrictions for the Segmented Management Instance.
You can configure a maximum of three Management Instance interfaces, one of each type; an Out-of-Band (OOB) management interface, a Circuitless IP (CLIP) management interface, and a VLAN management interface.
If you change the default route weight, the management interface with the lowest weight value becomes the default route for all segmented management interface traffic.
The VSP 8600 Series Segmented Management Instance does not support ACL based filters or use of ping with -Q option to change the internal priority of management traffic.
You can configure the default topology IP for LLDP and SONMP advertisements. Both LLDP and SONMP advertise the same topology IP. SONMP supports only IPv4 addresses. If multiple IPv4 addresses are configured on an OOB or VLAN management interface, the advertised IP priority is static IP address, then DHCP IP address, then link-local IP address.
IPSec is not supported on Segmented Management Instance management interfaces.
