A MAC access list is created to verify the sender's MAC address in the RA packet. You can view, create or delete a MAC access list.
Use this procedure to create a MAC access list or add a MAC address to the existing MAC access list.
 - Click FHS.
 - Click the MAC Access List tab.
 - Click Insert.
 - Configure the parameters for the MAC access list.
 - Click Insert.
MAC Access List field descriptions
Use the data in the following table to use the MAC Access List tab.
 Name  |
 Description  |
 Name  |
 Specify a name to create a MAC access list.  |
 Mac  |
 Specify the MAC address to add to the MAC access list, in (xx:xx:xx:xx:xx:xx) format.  |
 AccessType  |
 Specify allow or deny. By default, the access type is allow.  |
Use this procedure to display a configured MAC access list.
 - Click FHS.
 Name  |
 Description  |
 Name  |
 Mac  |
 AccessType  |
Use this procedure to delete the created MAC access list.
 - Click FHS.
 - Select a row from the MAC access list to delete.
 - Click Delete.
