Use the following procedure to display (true) sFlow statistics. Statistics for sFlow are cleared (false), by default.
Tip
You can configure the Stats tab to select only the columns you are interested in seeing. All the options appear, by default. To hide a column, click the down arrow on one of the menu headings, navigate to Columns, and select the check box for the column you want to hide.
- Click sFlow.
- Click the Stats tab.
- In the ClearStats column, double-click the field, and select true or false from the list.
- Click Apply.
Stats Field Descriptions
Use the data in the following table to use the Statistics tab.
Name |
Description |
Index |
Shows sFlow collector ID 1 and 2 |
DatagramCount |
Shows the number of datagrams that have been sent to the collector. |
ClearStats |
Shows whether the sFlow statistics are displayed (true) or cleared (false). The default is false. |
