Enabling the Gateway globally
Use this procedure to enable the Gateway at the global (switch-wide) level.
- Click SPBM.
- In the row for the SPMB, double click the McastSpbPimGwGatewayEnable field, and then select true.
- Click Apply.
SPBM field descriptions
Use the data in the following table to use the SPBM tab.
| Name | Description |
| McastSpbPimGwControllerEnable | Enables or disables the ISIS multicast SPM-PIM Gateway Controller node. |
| McastSpbPimGWGatewayEnable | Enables or disables the ISIS multicast SPM-PIM Gateway node. |
