Change the VRF instance as required to configure a Circuitless IPv6 interface on a specific VRF instance.
You can use a circuitless IPv6 (CLIPv6) interface to provide uninterrupted connectivity to your system.
- In the navigation pane, expand Configuration > IPv6.
 - Click IPv6.
 - Click the Circuitless IP tab.
 - Click Insert.
 - In the Interface field, assign a CLIP interface number.
 - Type the IPv6 address and prefix length.
Circuitless IPv6 Field Descriptions
Use the data in the following table to use the Circuitless IPv6 tab.
 Name  |
 Description  |
 Interface  |
 Specifies the interface to which this entry applies.  |
 Addr  |
 Specifies the IPv6 address to which this entry applies.  |
 AddrLen  |
 Specifies the prefix length value for this address. You cannot change the address length after you create it. You must provide this value to create an entry in this table.  |
                                 Name Note:
                            This field does not apply to all hardware platforms.  |
                                 Specifies the name assigned to the IPv6 CLIP address.  |
