Use the following procedure to view IS-IS accept policy information on the switch.
View IS-IS accept policy information:
Switch:1#show ip route vrf test
IP Route - VRF test
============================================================================ NH INTER
DST MASK NEXT VRF/ISID COST FACE PROT AGE TYPE PRF
1.1.1.5 255.255.255.255 1.1.1.5 GlobalRouter 0 0 ISIS 0 IB 200
1.1.1.13 255.255.255.255 Switch13 GRT 10 1000 ISIS 0 IBSV 7
1.1.1.200 255.255.255.255 Switch200 GRT 10 1000 ISIS 0 IBSV 7
5.7.1.0 255.255.255.0 5.7.1.1 - 1 7 LOC 0 DB 0
13.7.1.0 255.255.255.0 Switch13 GlobalRouter 10 1000 ISIS 0 IBSV 7
100.0.0.0 255.255.255.0 100.0.0.1 GlobalRouter 0 100 ISIS 0 IB 200
111.1.1.0 255.255.255.0 111.1.1.1 hub 0 111 ISIS 0 IB 200
Switch:1(config)#show isis spbm ip-unicast-fib
SPBM IP-UNICAST FIB ENTRY INFO
VRF DEST OUTGOING SPBM PREFIX IP ROUTE
VRF ISID ISID Destination NH BEB VLAN INTERFACE COST COST PREFERENCE
GRT - 101 1.1.1.13/32 Switch13 1000 1/7 10 44 7
GRT - 101 1.1.1.13/32 Switch13 1001 1/7 10 44 7
Total number of SPBM IP-UNICAST FIB entries 2
Switch:1(config)#show ip isid-list test
IP ISID LIST
List Name I-SID VRF
test 1 GlobalRouter
3 GlobalRouter
4 GlobalRouter
5 GlobalRouter
10 GlobalRouter
22 GlobalRouter
All 6 out of 6 Total Num of Isid Lists displayed
Switch:1(router-vrf)#show ip isid-list vrf red
IP ISID LIST red
List Name I-SID VRF
test1 11 1
12 1
13 1
14 1
15 1
Variable definitions
The following table defines parameters for the show ip isis accept command.
Variable |
Value |
vrf WORD<1-16> |
Displays I-SID list information for a particular VRF by name. |
vrfids WORD<0-512> |
Displays I-SID list information for a particular VRF ID. |
The following table defines parameters for the show ip isid-list command.
Variable |
Value |
vrf WORD<1-16> |
WORD<1-32> |
Displays I-SID list information for a particular I-SID list name. |
The following table defines parameters for the show ip route command.
Variable |
Value |
vrf WORD<1-16> |
The following table defines parameters for the show isis spbm ip-unicast-fib command.
Variable |
Value |
all |
Displays all IS-IS SPBM IP unicast Fowarding Information Base (FIB) information. |
id <1-16777215> |
Displays IS-IS SPBM IP unicast FIB information by I-SID ID. |
spbm-nh-as-mac |
Displays the next hop B-MAC of the IP unicast FIB entry. |
