If you configure the switch to operate in v2-v3 compatibility mode, the switch supports all IGMPv2 and v3 messages. The switch parses the group address of the messages. If the group address is out of SSM range and it is a v3 message, the switch drops the message. If it is a v2 message, IGMP snoop processes handle the message.
To troubleshoot issues with the IGMPv3 backwards compatibility feature, perform the following procedure.
Display the configured SSM static channels and display the configured SSM group range:
Switch:>enable
Switch:1#show ip igmp ssm-map
Igmp Ssm Channel
GROUP SOURCE MODE ACTIVE STATUS
233.252.0.1 192.0.2.200 dynamic false enabled
233.252.0.2 192.0.2.200 dynamic false enabled
233.252.0.3 192.0.2.200 dynamic false enabled
233.252.0.4 192.0.2.200 dynamic false enabled
233.252.0.5 192.0.2.200 dynamic false enabled
233.252.0.6 192.0.2.200 dynamic false enabled
233.252.0.7 192.0.2.200 dynamic false enabled
233.252.0.8 192.0.2.200 dynamic false enabled
233.252.0.9 192.0.2.200 dynamic false enabled
233.252.0.10 192.0.2.200 dynamic false enabled
10 out of 10 entries displayed
Switch:1(config)#show ip igmp ssm
Igmp Ssm Global - GlobalRouter
DYNAMIC LEARNING SSM GROUP RANGE
enable 233.252.0.0/255.0.0.0
Job Aid
The following table shows the field descriptions for the show ip igmp ssm-map command.
Field |
Description |
GROUP |
Indicates the IP multicast group address that uses the default range of 232/8. |
SOURCE |
Indicates the IP address of the source that sends traffic to the group source. |
MODE |
Indicates that the entry is a statically configured entry (static) or a dynamically learned entry from IGMPv3 (dynamic). |
ACTIVE |
Indicates the activity on the corresponding source and group. If the source is active and traffic is flowing to the switch, this status is active; otherwise, it is nonactive. |
STATUS |
Indicates the administrative state and whether to use the entry. If the status is enabled (default), the entry is used. If the status is disabled, the entry is not used but is saved for future use. |
The following table shows the field descriptions for the show ip igmp ssm command.
Field |
Description |
DYNAMIC LEARNING |
Indicates whether dynamic learning is enabled at a global level. |
SSM GROUP RANGE |
Indicates the IP address range for the SSM group. |
