The following table describes the fields for the show isis spbm ip-multicast-route all command.
Parameter |
Description |
Type |
Specifies the type of interface. The options include:
VrfName |
Specifies the VRF name of the interface. |
Vlan Id |
Specifies the VLAN ID of the interface. |
Source |
Specifies the group IP address for the IP Multicast over Fabric Connect route. |
Group |
VSN-ISID |
Specifies the GRT because IP Multicast over Fabric Connect within the GRT does not use a VSN I-SID. |
Data ISID |
Specifies the data I-SID for the IP Multicast over Fabric Connect route. After a BEB receives IP multicast data from a sender, the BEB allocates a data I-SID in the range of 16,000,000 to 16,512,000 for the stream. The stream is identified by the source IP address, group IP address, and the local VLAN the stream is received on. The data I-SID is a child of the scope or VSN I-SID. |
BVLAN |
Specifies the B-VLAN for the IP Multicast over Fabric Connect route. |
Source-BEB |
Specifies the source BEB for the IP Multicast over Fabric Connect route. |
The following table describes the fields for the show isis spbm ip-multicast-route detail command.
Parameter |
Description |
Source |
Group |
Data ISID |
BVLAN |
NNI Rcvrs |
Specifies the NNI receivers. |
UNI Rcvrs |
Specifies the UNI receivers. |
Source-BEB |
The following table describes the fields for the show isis spb-mcast-summary command.
Parameter |
Description |
SCOPE I-SID |
Specifies the scope I-SID. Layer 2 VSN and Layer 3 VSN each require a scope I-SID. |
SOURCE ADDRESS |
GROUP ADDRESS |
DATA I-SID |
Specifies the data I-SID for the IP multicast route. After a BEB receives IP multicast data from a sender, the BEB allocates a data I-SID in the range of 16,000,000 to 16, 512,000 for the stream. The stream is identified by the source IP address, group IP address, and the local VLAN the stream is received on. The data I-SID is a child of the scope or VSN I-SID. |
BVID |
Specifies the Backbone VLAN ID associated with the SPBM instance. |
LSP FRAG |
Specifies the LSP fragment number. |
HOST NAME |
Specifies the host name listed in the LSP, or the system name if the host is not configured. |
