The following table defines parameters for the show isis lsdb command.
Variable |
Value |
detail |
Displays detailed information about the IS-IS Link State database. |
level {l1, l2, l12} |
Displays information on the IS-IS level. The IEEE 802.1aq standard currently only defines the use of one hierarchy, Level 1. Level 2 function is disabled. |
local |
Displays information on the local LSDB. |
lspid <xxxx.xxxx.xxxx.xx-xx> |
Specifies information about the IS-IS Link State database by LSP ID. |
sub-tlv <1–3> |
Specifies information about the IS-IS Link State database by sub-TLV. |
sysid <xxxx.xxxx.xxxx> |
Specifies information about the IS-IS Link State database by System ID. |
tlv <1–236> |
Specifies information about the IS-IS Link State database by TLV. |
