Variable definitions
The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable
Value
all
Displays all IP Multicast over Fabric Connect route information.
detail
Displays detailed IP Multicast over Fabric Connect route information.
group{A.B.C.D}
Displays information on the group IP address for the IP Multicast over Fabric Connect route.
vlan<1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
vrfWORD<1–16>
Displays IP Multicast over Fabric Connect route information by VRF.
vsn-isid<1–16777215>
Displays IP Multicast over Fabric Connect route information by I-SID.
The following table defines parameters for the show isis spb-mcast-summary command.
Variable
Value
count
Displays the total number of SPB multicast entries.
host-nameWORD<0–255>
Displays the IP Multicast over Fabric Connect summary information by host-name.
lspid<xxxx.xxxx.xxxx.xx-xx>
Displays the IP Multicast over Fabric Connect summary information by LSP ID.
