Variable definitions
The following table defines parameters for the show ip igmp interface command.
Variable
Value
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
vlan <1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
vrf WORD<1–16>
Specifies the VRF by name.
vrfids WORD<0–512>
Specifies the VRF by VRF ID.
The following table defines parameters for the show ip igmp cache command.
Variable
Value
vrf WORD<1–16>
vrfids WORD<0–512>
The following table defines parameters for the show ip igmp group command.
Variable
Value
count
Specifies the number of entries.
group {A.B.C.D}
Specifies the group address.
member-subnet {A.B.C.D/X}
Specifies the IP address and network mask.
vrf WORD<1–16>
Displays the multicast route configuration for a particular VRF by name.
vrfids WORD<0–512>
Displays the multicast route configuration for a particular VRF by VRF ID.
The following table defines parameters for the show ip igmp sender command.
Variable
Value
count
group {A.B.C.D}
vrf WORD<1–16>
vrfids WORD<0–512>
