Variable definitions
The following table defines parameters for the show ip igmp interface command.
Variable
Value
gigabitethernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
vlan <1-4059>
Specifies the VLAN.
vrf WORD<1–16>
Specifies the VRF by name.
vrfids WORD<0–512>
Specifies the VRF by VRF ID.
The following table defines parameters for the show ip igmp cache command.
Variable
Value
vrf WORD<1–16>
vrfids WORD<0–512>
The following table defines parameters for the show ip igmp group command.
Variable
Value
count
Specifies the number of entries.
group {A.B.C.D}
Specifies the group address.
member-subnet {A.B.C.D/X}
Specifies the IP address and network mask.
vrf WORD<1–16>
Displays the multicast route configuration for a particular VRF by name.
vrfids WORD<0–512>
Displays the multicast route configuration for a particular VRF by VRF ID.
The following table defines parameters for the show ip igmp sender command.
Variable
Value
count
group {A.B.C.D}
vrf WORD<1–16>
vrfids WORD<0–512>
The following table defines parameters for the show ip igmp snoop-trace command.
Variable
Value
group {A.B.C.D}
source {A.B.C.D}
Specifies the source address.
vrf WORD<1–16>
vrfids WORD<0–512>
