The switch can query the number of ingress and egress IP multicast streams traversing the switch. After you configure the thresholds for ingress and egress records, if the record-usage goes beyond the threshold, the device notifies you by way of a trap on the console, logged message, or both.
If you do not configure the thresholds, the switch displays only the ingress and egress records currently in use.
Switch:1>show ip mroute hw-resource-usage
                       Multicast Hardware Resource Usage
EGRESS      INGRESS     EGRESS      INGRESS     LOG MSG   SEND TRAP  SEND TRAP
REC IN-USE  REC IN-USE  THRESHOLD   THRESHOLD   ONLY      ONLY       AND LOG
0           0           0           0           false     false      false
Job Aid
The following table shows the field descriptions for the show ip mroute hw-resource-usage command.
 Field  |
 Description  |
 EGRESS REC IN-USE  |
 Indicates the number of egress records (peps) traversing the switch that are in use.  |
 INGRESS REC IN-USE  |
 Indicates the number of source and group records traversing the switch that are in use.  |
 EGRESS THRESHOLD  |
 Indicates the egress records threshold.  |
 INGRESS THRESHOLD  |
 Indicates the source and group records threshold.  |
 LOG MSG ONLY  |
 Indicates the status of logging messages only.  |
 SEND TRAP ONLY  |
 Indicates the status of sending traps only.  |
 SEND TRAP AND LOG  |
 Indicates the status of both sending traps and logging messages.  |
