If traffic is not moving properly, use the following procedure to determine the
            issue.
                Ensure that all switch nodes in
                    the network operate with the most recent software release to support IP
                    Multicast over Fabric Connect:
                Ensure that all ERS 8800 nodes
                    in the network have the current release:
                Ensure that you create and
                    enable SPBM infrastructure globally.
                        Ensure that SPBM is
                            enabled globally:
                        Ensure that IS-IS is
                            enabled globally:
                        Ensure an SPBM instance
                            exists and at least one Backbone VLAN exists (B-VID). Also ensure
                            multicast is enabled:
                Ensure that you enable the CFM
                    configuration.
                        Ensure a CFM
                            maintenance-association exists:
                            show cfm
                        Ensure a CFM
                            maintenance-domain exists:
                            show cfm
                                    maintenance-domain
                        Ensure a
                            maintenance-endpoint exists in the MEP ID column and is enabled in the
                            ADMIN column:
                            show cfm
                Ensure the following on all BEBs
                    where you want IP Multicast over Fabric Connect. Ensure that you enable IP
                    Multicast over Fabric Connect globally:
                On the VLANs that need Layer 3
                    VSN IP Multicast over Fabric Connect routing, create an IP interface on the VLAN
                    if one does not exist. The address should be on the same subnet as the IGMP
                    hosts connected to the VLAN. Also, ensure that you enable IP Multicast over
                    Fabric Connect. Create an IP interface on the VLAN and enable IP Multicast over
                    Fabric Connect.
        Enter VLAN Interface Configuration
          mode:
          enable
          configure
              terminal
          interface vlan <1–4059>
                    VLAN and enable IP Multicast over Fabric Connect:
                    ip address <A.B.C.D>
                    ip spb-multicast
                            enable
                Ensure that you enable IGMP
                    Snooping on access Layer 2 switches to prevent flooding of multicast traffic to
                    non-receiver ports:
                    show ip igmp
                            snoop-trace
                    show ip igmp
                            interface
                Ensure that the IGMP version
                    used by the multicast hosts and the Layer 2 switches outside the SPBM network is
                    the same as the IGMP version configured on the C-VLAN:
