Perform this procedure to display the port shortcut menu.
- In the Device Physical View, select a port.
- Right-click the selected port.
Port shortcut menu field descriptions
Use the data in the following table to use the port shortcut menu.
| Name | Description |
| Edit General | Configures the general options for the port. |
| Edit IP | Configures the IP options for the port. |
| Edit IPv6 | Configures the IPv6 options for the port. |
| Channelization Enable | Enables channelization for the port. |
| Channelization Disable | Disables channelization for the port. |
| Graph | Displays the statistics for the port. |
| Enable | Enables the port. |
| Disable | Disables the port. |
