Perform the following procedure to display the chassis shortcut menu.
- In the Device Physical View, select the chassis.
- Right-click the chassis.
Chassis shortcut menu field descriptions
Use the data in the following table to use the Chassis shortcut menu.
| Name | Description |
| Edit | Edits chassis parameters. |
| Graph | Graphs chassis statistics. |
| Refresh Status | Refreshes the status of the chassis and MDAs. |
| Refresh Port Tooltips | Refreshes the port tooltip data of the system. The port tooltip data contains the following variables: Slot/Port, PortName, and PortOperSpeed. |
