View IP Source Guard (IPSG) configuration on a port, with filters for IPv4 addresses.
Switch:1>show ip source verify interface gigabitEthernet 4/1
                             Source Guard Port Info
PORT
NUM        ENABLE
4/1        true
All 1 out of 1 Total Num of Ip Source Guard entries displayed
The following table defines parameters for the show ip source verify interface gigabitEthernet command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
