View the IPv4 address bindings that IP Source Guard (IPSG) allows.
View the allowed IPv4 address bindings for the port 4/1.
Switch:1>show ip source binding interface gigabitEthernet 4/1
                                                   IPSG Source Table
PORT       IP              VLAN    VRF
NUM        ADDRESS         ID      NAME
4/1        192.0.2.1       200     GlobalRouter
All 1 out of 1 Total IP Source Guard entries displayed
View the IPv4 address bindings for a specific IP address.
Switch:1>show ip source binding 192.0.2.1
                                                   IPSG Source Table
PORT       IP              VLAN    VRF
NUM        ADDRESS         ID      NAME
The following table defines parameters for the show ip source binding command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Identifies the IPv4 address.  |
 interface gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 vlan <1-4059>  |
 Specifies the VLAN ID of the VLAN for which to view IPv4 address bindings.  |
 vrf WORD<1-16>  |
 Specifies the VRF name of the VRF for which to view the IPv4 address bindings.  |
 vrfids WORD<0-512>  |
 Specifies the VRF ID of the VRF for which to view IPv4 address bindings.  |
