You can assign a VRF instance to a port or VLAN. You cannot associate a VLAN or port and a VRF instance if the VLAN or port has an IP address. You can configure the IP address after you associate the port and VRF instance.
- Ensure the VRF is already configured.
Switch:1> enable Switch:1# configure terminal
Create a VRF named Two:
Switch:1(config-if)# ip vrf Two
Create a VLAN of type byport:
Switch:1(config-if)# vlan create 33 name vlan-30 type port-mstprstp 0
Enter VLAN Interface Configuration mode:
Switch:1(config-if)# interface vlan 33
Assign the VLAN to VRF Two:
Switch:1(config-if)# vrf Two
Give the VLAN an IP address:
Switch:1(config-if)# ip address 192.0.2.1 255.255.255.0
Enter VRF configuration mode:
Switch:1(config-if)# router vrf Two
Variable definitions
Use the data in the following table to use the vrf command.
| Variable | Value |
| vrf WORD<0-16> | Specifies the VRF instance by name. |
