Create a VRF Instance
Create a VRF instance to provide a virtual routing interface for a user.
For more information on route scaling, see Release Notes for VOSS.
Create a VRF instance:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip vrf vrfRED
Configure the maximum number of IPv4 routes and enable max-routes traps.
Switch:1(config)#ip vrf vrfRED max-routes 12000 Switch:1(config)#ip vrf vrfRED max-routes-trap enable
Enter Router Configuration mode and configure the routing protocol triggers for the VRF:
Switch:1(config)#router vrf vrfRED Switch:1(router-vrf)#ip bgp Switch:1(router-vrf)#ip ospf Switch:1(router-vrf)#ip rip
To Configure OSPFv3 instance for the VRF:
Switch:1(config)#router vrf vrfRED Switch:1(router-vrf)#ipv6 ospf
Exit to Global configuration mode:
Switch:1(router-vrf)#exit
Configure the maximum number of IPv6 routes and enable IPv6 max-routes traps.
Switch:1(config)#ip vrf vrfRED ipv6-max-routes 7700 Switch:1(config)#ip vrf vrfRED ipv6-max-routes-trap enable
Ensure that the instance is configured correctly:
Switch:1#show ip vrf vrfRED
                                VRF INFORMATION
VRF        OSPF       RIP        BGP        PIM        ARP        PIM6        OSPFv3
COUNT      COUNT      COUNT      COUNT      COUNT      COUNT      COUNT       COUNT
1          1          1          1          1          7          1           1
VRF           VRF                                  VLAN    ARP
NAME          ID   OSPF    RIP     BGP     PIM     COUNT   COUNT   PIM6       OSPFv3
vrfRED        3    TRUE    TRUE    TRUE    TRUE    0       7       TRUE       FALSE
1 out of 1 Total Num of VRF Entries displayed.
The following table defines parameters for the ip vrf command.
| Variable | Value |
| Depending on your hardware platform: max-routes <max-routes> | Specifies the maximum number of IPv4 routes for the VRF. Depending on the hardware platform, the parameter range and default value can vary. Use the CLI Help to see the available range for the switch. For route scaling information, see Release Notes for VOSS. |
| ipv6-max-routes <max-routes> | Specifies the maximum number of IPv6 routes for the VRF. Depending on the hardware platform, the parameter range and default value can vary. Use the CLI Help to see the available range for the switch. For route scaling information, see Release Notes for VOSS. |
| max-routes-trap enable | Enables SNMP traps after the maximum number of IPv4 routes are reached. |
| ipv6-max-routes-trap enable | Enables SNMP trap generation based on the configured number of maximum IPv6 routes. The default is enabled. |
| name WORD<0-16> | Renames the VRF instance. |
| vrf-trap | Enables the device to send VRF-related traps. |
The following table defines parameters for the show ip vrf command.
| Variable | Value |
| max-routes [vrfids WORD<0-512>] [WORD <1–16>] | Displays the maximum number of routes for the specified VRFs.
| vrfids WORD<0-512> | Specifies a list of VRFs by VRF IDs. |
| WORD<1-16> | Specifies a VRF by name. |
