Use the following procedure to verify the proper global SPBM configuration.
Switch# show isis spbm
ISIS SPBM Info
SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW STP-MULTI
INSTANCE VLAN NAME TRAP HOMING
1 4051-4052 4051 disable disable disable enable disable enable
ISIS SPBM SMLT Info
SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID
INSTANCE
1 primary 00:00:00:00:00:00
Total Num of SPBM instances: 1
Switch# show vlan basic
Vlan Basic
VLAN INST
ID NAME TYPE ID PROTOCOLID SUBNETADDR SUBNETMASK VRFID
1 Default byPort 0 none N/A N/A 0
10 VLAN-10 spbm-bvlan 62 none N/A N/A 0
20 VLAN-20 spbm-bvlan 62 none N/A N/A 0
100 VLAN-100 byPort 0 none N/A N/A 0
All 5 out of 5 Total Num of Vlans displayed
Job aid
The following table describes the fields in the output for the show isis spbm command.
Parameter |
Description |
SPBM INSTANCE |
Indicates the SPBM instance identifier. You can only create one SPBM instance. |
B-VID |
Indicates the SPBM B-VLAN associated with the SPBM instance. |
PRIMARY VLAN |
Indicates the primary SPBM B-VLAN. |
NICK NAME |
Indicates the SPBM node nickname. The nickname is used to calculate the I-SID multicast MAC address. |
LSDB TRAP |
Indicates the status of the IS-IS SPBM LSDB update trap on this SPBM instance. The default is disable. |
IP |
Indicates the status of SPBM IP shortcuts on this SPBM instance. The default is disable. |
IPv6 |
Indicates the status of SPBM IPv6 shortcuts on this SPBM instance. The default is disable. |
MULTICAST |
Indicates if SPBM multicast is enabled. The default is disabled. |
SPB-PIM-GW |
Indicates if SPB PIM Gateway is enabled. The default is disabled. |
STP-MULTI HOMING |
Indicates if MSTP-Fabric Connect Multi Homing is enabled. The default is disabled. |
SMLT-SPLIT-BEB |
Specifies whether the switch is the primary or secondary vIST peer. |
SMLT-VIRTUAL-BMAC |
Specifies a virtual MAC address that can be used by both peers. |
SMLT-PEER-SYSTEM-ID |
Specifies the vIST peer system ID. |
