Use the following procedure to display the global IS-IS parameters.
Switch# show isis
                               ISIS General Info
                            AdminState : enabled
                            RouterType : Level 1
                             System ID : 0014.c7e1.33df
                  Max LSP Gen Interval : 900
                                Metric : wide
                   Overload-on-startup : 20
                              Overload : false
                         Csnp Interval : 10
                         PSNP Interval : 2
                     Rxmt LSP Interval : 5
                             spf-delay : 100
                           Router Name : Switch1
                     ip source-address : 192.0.2.0
                   ipv6 source-address : 41:0:0:0:0:0:0:100
              ip tunnel source-address : 192.0.2.10
                            Tunnel vrf : spboip
                              ONA Port : 1/15
                         ip tunnel mtu : 1950
                     Num of Interfaces : 2
                 Num of Area Addresses : 1
                        inband-mgmt-ip :
                              backbone : disabled
              Dynamically Learned Area : 00.0000.0000
                            FAN Member : No
The ONA Port : 1/15
          parameter in the preceding example is applicable only to the VSP 4450
					Series.
Switch# show isis system-id
                                 ISIS System-Id
SYSTEM-ID
0014.c7e1.33df
      Switch# show isis net
                                 ISIS Net Info
NET
c0.2000.0000.0000.14c7.e133.df00
  Job aid
The following sections describe the fields in the outputs for the global IS-IS show commands.
show isis
The following table describes the fields in the output for the show isis command.
| Parameter | Description |
| AdminState | Indicates the administrative state of the router. |
| RouterType | Indicates the router Level: l1, l2, or l1/2. |
| System ID | Indicates the system ID. |
| Max LSP Gen Interval | Indicates the maximum time between LSP updates in seconds. |
| Metric | Indicates if the metric is narrow or wide. |
| Overload-on-startup | Indicates the IS-IS overload-on-startup value in seconds. The overload-onstartup value is used as a timer to control when to send out Link State Packets (LSPs) with the overload bit cleared after IS-IS startup. The default value is 20 seconds. |
| Overload | Indicates if there is an overload condition. |
| Csnp Interval | Indicates the interval between CSNP updates in seconds. |
| PSNP Interval | Indicates the interval between PSNP updates in seconds. |
| Rxmt LSP Interval | Indicates the received LSP time interval. |
| spf-delay | Indicates an SPF delay in milliseconds. The default value is 100 milliseconds. |
| Router Name | Indicates the IS-IS name of the router. |
| ip source-address | Indicates the IP source address used for SPBM IP shortcuts. |
| ipv6 source-address | Indicates the IPv6 source address used for SPBM IP shortcuts. |
| ip tunnel source-address | Indicates the IP tunnel source address used for SPBM Fabric Extend. |
| Tunnel vrf | Indicates the name of the vrf that contains the tunnel endpoints. |
| ONA Port |  Indicates the port to which the ONA device is attached. Note:
                                         The ONA port parameter is applicable only to the VSP 4450 Series. |
| ip tunnel mtu | Indicates the maximum size of a packet that can be transmitted through the IP tunnel. |
| Num of Interfaces | Indicates the number of interfaces on the router. |
| Num of Area Addresses | Indicates the number of area addresses on the router. |
| Num of Summary Address | Indicates the summary of the addresses on router. |
| inband-mgmt-ip Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Indicates the DvR management IP address for this node, in the DvR domain. |
| backbone | Indicates whether this node is part of the DvR backbone. |
| Dynamically Learned Area | For Fabric Area Network (FAN) members, specifies the IS-IS area that is dynamically learned from the neighbor‘s Hello PDU if the node does not have the IS-IS manual area configured. |
| FAN Member | Indicates whether the node is a member of the FAN. |
show isis system-id
The following table describes the fields in the output for the show isis system-id command.
| SYSTEM-ID | Shows the system ID. Output from this show command is from the global IS-IS configuration of the system ID. There is one system ID configured. The system ID is 6 bytes in length. |
show isis net
The following table describes the fields in the output for the show isis net command.
| NET | Shows the NET address. Output from this command is from the global IS-IS configuration of the manual area and the configuration of the system ID. There is only one manual areas defined and only one system ID. The manual area is from 1-13 bytes in length. The system ID is 6 bytes in length. |
