Use statistics to help monitor the performance of the switch.
To reset all statistics counters, click Clear Counters. After you click this button, all Cumulative, Average, Minimum, Maximum, and LastVal columns reset to zero, and automatically begin to recalculate statistical data.
Important
The Clear Counters function does not affect the AbsoluteValue counter for the device. The Clear Counters function clears all cached data in EDM except AbsoluteValue. Perform the following steps to reset AbsoluteValues.
