Perform this procedure to display information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
Switch:1>show energy-saver eee statistics
                                EEE Port Status
         EEE           Tx          Tx              Rx           Rx
PortId   Status        LPI Events  Idle Duration   LPI Events   Idle Duration
                                   (micro seconds)              (micro seconds)
1/1      enabled       847         963657920       115          965100020
Use the data in following table to use the show energy-saver eee statistics command.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
